I need some help, Ive got a 2006 Titan its got 146000 miles and sometimes when I go to start it I can smell a small sent of gas. it also takes about 5 to 10 seconds to start. after it starts I don't have an issue. its got me confused. Thanks....
Crack manifold or leaky b pipe maybe for the gas type smell.....you should here ticking while accelerating from inside the truck.Taking a while to start could be a lot of things. Since you have no drivability issues id start with the battery.
Could also be that your fuel pressure is dropping out from a leak while it sits. Next time you start it cold, first turn the key on and wait 15 seconds (to let the fuel pump pressurize the system) then turn it over. If it starts right away, maybe you've got a leak in the fuel rail? Just a thought....
