Hello.
After reading about the mods I can do on my 2004 truck. I decided to go for the TT DIY route. My truck only has 45K miles on it, so why not.
Let's get started.
total: $659.19
PML Differential Covers (10756AS) $185.00
Ah, this is a 2004 model. So this gets even more expensive.
I hope these are the right parts.
36522-8S10A BRACKET
24211-8S10A CLIP
Total: $26.61
The PML diff cover wasn't painted. I ended up spray painting it with
This will reduce EMI/RFI interference with the rear diff.
Item G8HBZN-W1-NF038-0100
Description 3/8-24 x 1 Hex Cap Screw, Grade 8 Alloy Steel, Zinc Plated Yellow, 1 Hole Drilled Thru Head (7/64)
Qty 25.00
Unit Price $2.00000
Total $62.50
Permatex 27200 + 12 Grade 8 washers =$20.97
From eBay Milbar M7 2W SafteyTwist Lock Wire Twister Pliers Aircraft Aviation Industrial $47.45
Malin - MS20995C Stainless Steel Safety Wire / Lockwire | .032" Dia , Can $15 Is this the right diameter?
Removed the black bolts and it is hard to tell but there is some blue stuff on them. I found some of the bolts were easier than others to take off.
I really don't know what this means. When I first put on the new bolts the washers went over the slotted area. So I filed them down, hoping I won't run into any issues.
55 ft. lbs torque right?
I am going to stop now. And work again on this tomorrow as I need to read up and watch videos on safety wire.
Here are some spare parts.
Let's get started.
total: $659.19
36522-8S10A BRACKET
24211-8S10A CLIP
Total: $26.61
Qty 25.00
Unit Price $2.00000
Total $62.50
