1 - 20 of 41 Posts
Got my Truxedo cover on Wednesday. Picked it up at the factory and the staff there were great! May even get some pictures of my truck in the Truxedo marketing ads for the Titan!!!
Absolutely love it! Fits on top of the utili-track system and is only about an 1 inch above the sides of the truck. Fits nice and tight, no water leaks, and looks great.
Will post some pictures later for you all to see.
... Did you get the low profile cover? Like the one I have my truck? Or did you get there reg. cover? Also did you install the tie-down cleats before the cover went on? Because they will not fit in the trac's after the rails are on.
Hello Deepwater:
I was just wondering if you knew the tie-downs will come out of the trac without sliding them out the end? My salesman told me that, so they wouldn't get stolen out of the bed. If you loosen them enough, they fall right out where they are. FYI :)
NITEBLITZ
NITEBLITZ said:
Hello Deepwater:
NITEBLITZ
Yes you are right! BUT if you don't install the cleats first the only way to get them on is by sliding them down the tracks! The Cleats are to big and when you try to trun them Verticaly to slide them in the tracks they wont fit into the tracks! Because they hit the rails of the cover! I think this is good because they are alot harder to steal! When you try to turn them from Horizontal to Vertical, like you would if you were trying to take them off. They hit the rails! So if you lock the tailgate, they would have to dismantle the hole cover to get to them! I supose you can just slid them through the ends of the tracks each time but if you have the extender this could become a hassle.. I hope you can understand this, it's alittle hard to explain. :)
Yes I got the low profile cover. I did install the cleats before installation, but do not see this as a big issue.
I was real happy with all the staff at Truxedo. Very professional and aim to please. It will be neat to see if my truck gets published in their marketing material.
I understand now, glad your cover turned out to be a keeper for you! :thumbsup:
NITEBLITZ
Well I was looking at mine again. And I dont see how you can install the cleats after the cover has been put on without removing the clamps! I see now that you can't just slid them on after the fact because of the first CLAMP for the frame is in the way! So I see that you must install all of them first like I did! OR remove the clamps! Just thought I would let people know about this, it's easyer and makes sence to put them on first! :)
Thanks for the tip, DeepWater. My Truxedo Lo Profile will arrive this Friday. I got it at Tellico4x4.com for $394.90 shipping included. I saw the pics you posted and ordered it right then.
You got a great price on the cover!! I payed $419.00 installed. And around my area that was the best price I could find at the time. Alot of dealers were at $450.00/$475.00 installed! They were all telling me the old reg. style covers were $395.00. BUT because this was a New Style cover it cost a little more. I new they were giving me a line! But I wanted it, so I payed. I hope Everybody Loves there TruXedo as much as I do mine! :cheers:
LI Titan said:
Where did the cover clamps mount ? Did they mount on the uliti-track?
They have two different types of clamps. Both will work! The clamps that are for the utili-track set up mount inside of the tracks. The other clamps mount out side of the tracks, in the four corners. The clamps that fit inside of the utili-track are alot stronger though. :)
Discussion Starter · #14 ·
Truxedo Cover
Here are some pictures of the Truxedo cover. I have been very impressed with the form and fit with the Utili-Track system!
looks great texas titan thabks for for the pics so everyone can see what it looks like can you install the banks for us :jester: j/k
My Truxedo Lo Profile still hasn't arrived (ordered on 3/9). I hope it will be in on Monday. I'm also hoping that it will have the clamps for the Utili-Track. I did get it for $394.90 shipping included as I've stated earlier.
Discussion Starter · #17 ·
I am sure you will be pleased with it. I really enjoy mine. Loaded my truck this weekend and the cover stayed tight and secure. Good luck and enjoy!!
slick said:
one question, how do i move my bed divider around, or remove it when i want to put my bed extender in and take the divider out.
The Crew cabs do NOT need the middle clamps!
He installed them anyway. But they are not needed! Now on the Reg. cabs you do need to install the middle clamps because the frame rails are longer. On my truck I used one (utili-track clamp) on the back end of the tracks because they are alot stonger! I have a crew cab so I didn't use the middle clamp. I than used a self tapping screw on the end by the tail gate. You can use a nut and blot if you want, but the frames are fairly light. With this set up you can slide your bed extender fully front to back! And if you want to open the extender onto the tailgate, you just slide it off the tracks flip it up and slide it back on! All of about 15/20-seconds to do this. It's very easy! I hope this information helps you understand alittle better how to make this work with the sliding extender/divider. :)
Finally, my Truxedo Lo Profile came in today. We just finished installing it. It was pretty easy as has been said in this forum. It however took us a little longer because we did not understand some of the terminologies.
We installed it with the regular clamps, not the utili-track clamps. I guess I'll have to request it from Truxedo. I think its true that the cover will be stronger using the clamps for utili-track since we'll be able to use 3 clamps on each side. As of now, we are only using 2 of the 3 regular clamps since there is no place for the middle clamp.
All-in-all, it was great! Galaxy Black with Black tonneau cover! I highly recommend this cover...lifetime warranty too! My Titan just keeps getting better.
1 - 20 of 41 Posts
