04 4x4 2.94 open diff. Installing truetrac. Looks like the TT(913A582) is a 32 spline. Im assuming seeing as the ring and pinion is a 24 spline that I am going to have to get the 24 spline pinion flange(2006269) as well?
if you are doing just a TT install you dont touch the pinion at all. Just swap out the carriers. less than 2 hour job.04 4x4 2.94 open diff. Installing truetrac. Looks like the TT(913A582) is a 32 spline. Im assuming seeing as the ring and pinion is a 24 spline that I am going to have to get the 24 spline pinion flange(2006269) as well?
