I got the leveling kit installed 2 days ago and decided to test it out yesterday. I got home after doing a bit of light offroading and checked to make sure everything was still in place. Then i noticed that i had a few dings in my coilover bucket that lined up perfectly with the UCA. Has anybody else had this problem? Do you guys know what i should check? I want to fix this before it becomes a major problem.:newgrin:
the stock ucas will contact the coilbucket. thats the reason for 3 options for aftermarket ucs...500 bucks will set you straight and give you more droop when they avoid the coilbucket
I wasnt expecting to have the problems with just a leveling kit though. Granted, it only happens when im off roading and the front comes off the ground or extends fully. Stupid junk stock UCA....
Supporting Vendor (Gold)
All the current spacer kits let the upper arm hit the coilbucket. Ours do it much less than the others (why we've been building different 2 or 4wd kits for the last couple years). The most lift you can get without interference is 1.3" . But you should have no probelms. But if your front tires are leaving the ground, i really suggest you get a good set of coilovers.
I plan on getting some DRs and some of your new UCA's in the next month or so, but until then, i guess ill just have to resist from offroading...
