I can't believe it, I came out to my truck after work today, and found that my Undercover Tonneau has melted. Great. It's a little over a year old I think, so hopefully it will be under warranty. It was only around 100 degrees or so today, very hot, but it shouldn't be melting my tonneau!
So now here goes the battle with Warranty, I will keep you posted as to how this turns out.
But if you live in the South and have a Undercover or similar, you might be wary!
It melted right around the center area, when I found it, it was very hard to the touch, not soft, I can't believe this could happen. If I had a giant magnifying glass or something perhaps. The inside looks fine, and the bed was empty. except for a bed-liner. My only possible thought is that too much heat got trapped inside the bed?
Here is a post from when I got my Tonneau which was February 21st 2006..
http://www.titantalk.com/forums/450961-post12.html
According to the website it has a 3 year warranty on the composite parts.
http://www.undercoverinfo.com/warranty.html
