1 - 8 of 8 Posts
Hey guys,
Does anyone know how to update the Cipher cable's firmware version? Every time I plug the cable in while the programs open, an error message opens up and says I need to update to version 1.73 or newer, then closes. I've looked at their Support page and haven't seen anything to update it. I replaced all the UI drivers from their site into my files, and nothing.
Any help?
Thanks!!
First, you should run the Software Updater from Uprev to download the lastest files.
Next, check to the Uprev folder where you installed Uprev (typically: c:\program files\uprev). In that folder there should be a Cable Manager folder. Within the Cable Manager folder there is an .exe file, CableManager.exe file which you can execute. The newer cable firmware should be in that folder as well.
Don't you have to plug the cable in first before you open the Cipher/Osiris program's?
Thanks guys, I finally got it.
Not for me, I can open the program and then plug the cable in and it works fine for me...
I didn't realize at first, the need to plug a cable in to just look at an Osiris application. Duh. Instructions and Interface can be greatly improved. Love the results though, and Updates are easier than in the past.
I've never needed to update mine.
I had to update mine a few months ago. It would not let me get in when I was connected to my truck.
1 - 8 of 8 Posts
