861 - 880 of 921 Posts
I own a few .com companies tinyuploads.com being one. You can use it to upload your images it saves them for you manages them and you can use the easily auto created links to post on forums. It also stores music , it's free and better then buying a chip.
sig pic....
Super Moderator
RNP sig pic.
The message you have entered is too short. Please lengthen your message to at least 10 characters.
Signature pics
One more! :bangit:
:redblob"The Modifications:redblob"​
Suspension: Pro Comp 6" Stage 1, Rear Pro Comp MX6 shocks, RC UCA's, DK Cam Bolts, Fox 2.0 Front Coilovers 1" of preload, 3" rear blocks, PRG drive shaft spacer, no sway bar
Performance: Reso Cajun B-pipes, Borla Xr1 3" 40943, FM Y-Pipe, NISMO Intake, UpRev'd Cajun Style, Cajun Axle Vent kit, Reaper IAT mod, PRG Diff cover, Royal Purple 10w-30 engine oil, Royal Purple 75w-140 rear gear oil
Lighting: 7" 55w 6k HID AUX lamps, 35w 6k lows halogen highs in Spyder headlights with halogen highs, all LED interior lights from LSAL
Tires: 35x12.50r18 Federal M/T's, stock rims, 1.5" wheel adapters
Looks: Bedlined rims, DIY Grille Mod, De-badged, Factory bedliner, painted engine cover, 550 Paracord Grab Handles, N-Fab RSP bumper, Titantalk.com decal to represent, factory matched front tint
Audio: Pioneer Double DIN touch screen, all Metra install gear, custom three pin relay e-brake bypass for video
On the list to be installed/bought: JBA LT's, Tire Carrier, and Audio Gear.
How do you make the pictures large instead if the postage stamp size ones?
Super Moderator
Reactions: gweasel77
MODS
Interior: 2 10" MMATS P2.5's, MMATS M600.1D Amp, Tech12Volts Box, and LegitLED Blue Interior Lighting
Exterior: CST Lift Spindles, 2" PRG Leveling Spacer; Bilstein 5100s; Deaver C-30 Leafs; 1" Rear Blocks; CST CBDB; Bilstein 5125s; R1 Concepts Drilled and Slotted Rotors; Centric Posi Quiet Ceramic Brake Pads; Black Rhino Ocotillo 18x9 -12; 35x12.5x18 Nitto Trail Grapplers; Tinted Front Windows and Eyebrow on Windshield; LegitLED Super Reverse 3.0s, Third Brake Light, and Cargo Lights; and LSAL License Plate Lights
Performance: Airraid MXP Intake, Borla XR-1, and Bullydog Power Pup (Regular Tune, WOT Restriction Removed, +2 Timing)​
2008 Titan
Mods: AirAid MXP, BullyDogPP, 18" Helo's, 1 1/2 Billet Wheel Spacer, 2" billet spacer (front), Bilstien 5100's on all 4 corners, 1" rear block, Pioneer AVH2400, RE 1500 mono powering 2 RE 10s in a tech12volts box, bull bar, armada air dam, BackFlip HD Tonneau, Modded Headlights, Black Mesh Rivit Grille.
This is meant as a true compliment.
If Nissan ever wants to directly compete with the Ford Raptor, they should
hire you as a consultant.
It would be really neat to see something like your rig on the showroom floor!
2005 Nissan Titan Crew Cab SE 2wd
Exterior: 4" Maxtrac Spindle Lift, 2.5" PRG leveling kit, 2" Maxtrac rear block, 295/70/18 Nitto trail grapplers, 18x9" XD Signature Series Rockstars, N-Fab nerf bars, Bushwacker pocket style fender flares, Paramount Restyling grille, Leer 700 series tonneau cover, Black modded headlights, Plasti-Dipped (Door handles, mirror caps, front & rear bumpers, stars), Color-Matched (Grille bolts, flare bolts, wheel trim, center caps, engine cover), Red LEDs behind grille,OEM BT mirrors
Interior: LSALighting RED interior LED swap, 2 12" Red LED strips in the front, 2 8" Red LED strips in the rear, 7" Sony in-dash touchscreen, 2 12" Kicker CompVRs in a shallowmount box
Not to be a jerk but that truck wouldn't keep up with a raptor off road.
DroidWhoring
