1 - 18 of 18 Posts
Hi Ya'll! I just ordered Uprev and I have one question.
when doing the 0 to 60 runs for log, is it better to do them with my stock tires, or can I leave my 22's? sorry guys I'm still a newbee:hi:
Doesn't really matter, just use the one that you use the most. You are doing logs not 1/4 mile times.
Reactions: VinylImagez
You'll get higher numbers with the 17s. When I dynoed mine I kept my 20s on. Got lower numbers, but real world numbers. 17s numbers look better on paper.
Discussion Starter · #8 ·
thanks Guys, guess I'll leave my 22's on, It's just for data login, My truck has been running like sh!t with no tune.
I know uprev takes about 1 to 2 weeks before they send you back the custom tune, but how about the base tunes? are they ok?
reason I'm asking is because it is REALLY running like Sh!t and cant wait till I at least flash the ecu with the base tune.
Discussion Starter · #10 ·
thanks Turbo!
Log with the 22's since it is the larger wheel, then go to the track with your stocks. LOL That is what I would do at least.
I just data log w/ my 22's on. It's too much of a PITA to switch rim's & tires every time you want to log 0-60's.
Be patient, Up/Rev is in the middle of moving into their new expanded facility. Yes, it does take a week or two sometimes to get your new ROM file back depending on how busy they are that week. It will be well worth the wait. :)
We need an update Vinyl............................my base tune was great:)
Discussion Starter · #14 ·
some how I can't upload the file with out been zipped, I havent send the datalogs to uprev for fine tunning, (this one is a run from the base rom).
Im waiting to install cams, them I will send the logs for fine tunning.
I don't understand these number LOL! can some one explain? thanks!
Gil!!
Discussion Starter · #15 ·
I'm gonna do sum more 0-60 runs tonight , I'm not happy with the 7.69 sec.
Discussion Starter · #17 ·
thanks Turbo!, I'm starting to understand the AFR's, looks like she has a bit more room for them to tweek, :)
There's a couple of discrepancies w/ this log. I think you need to do another one to be sure. Your calculated load isn't steady the whole run. Try getting to WOT as soon as possible when doing a data log for tuning purposes. When @ WOT the calculated load should be 100% the whole time & the TPS should be at 4.+ volts.
1 - 18 of 18 Posts
