1 - 20 of 67 Posts
Incase anyone hasn't heard yet, you can now get the burnout mod done through Uprev instead of cutting wires.
Does it just use one of the settings to disable ABS?
I'm not entirely sure but they just add it to your rom an voila burnout time
I saw that earlier.
Not that I want to even think about doing a burnout on tires as expensive as mine but...pretty sweet to have that ability now!
Reactions: GalaxyPro4X11
I saw that earlier.
I have lots of spare tires to burn off. Looking forward to it an maybe for this summers drag races in town that I'm going to try an make
Exactly what I was thinking. Been meaning to buy a second spare to have a set of crap tires on I can play around with.
Tire Alloy wheel Rim Automotive tire Wheel
i wouldn't dare burn these off
I mean, if you have so many spares...Memphis isn't so far away...haha.
Discussion Starter · #10 ·
Reactions: bender2
Where did you find this out?
I personally saw it from Mike, the man himself on the FB TT page.
He said that he talked to Joe earlier today, so he should be aware.
Reactions: nightowl
Discussion Starter · #12 ·
Randy told me today he was working on adding all the ecu's and confirmed mine is good to go. Now to just get out of camp an home to The truck an laptop.
That wouldn't go on your daily driver map, right?
Run! Run like the wind!
Who doesn't love a good wal-mart parking lot burnout every once in a while?
If it applies to the whole Rom, then all maps will be affected.
I'm assuming all it does it give you the option to turn the locker on outside of 4lo, correct? I'm fairly certain just because the mod is integrated on your map, it doesn't just lock your axle full time. I hope not anyway. May still be worth a dedicated map for some of you hooligans out there haha, but I'd probably pass.
Discussion Starter · #17 ·
No bud like I was saying I wish it did that. It stops you ecu from pulling power when you apply brake with gas trying to do a burnout.
Go out an try a 5 second burnout or long enough to see what I'm talking about
Reactions: nightowl
Discussion Starter · #18 ·
This is good for the track guys or red light racers lol. Will be able to load the engine without power being pulled
So I can beat all the crappy Camaros we have around here :big_grin:. So many base ones that are just loud and nothing else. Basically like Mustangs, but Memphis people seem to have a preference for Chevy.
1 - 20 of 67 Posts
