uprev??
3168 Views 15 Replies 10 Participants Last post by  dcracing2
I have a 2007 titan with aem intake, tbs and banks exhaust. also changed my gears to 3.36. My cruise wont work because of the gearing.
Can someone just download the map into my truck or do i need to buy the whole thing?
It works with 87 octane also right?
I want to get ride of the bypass that wont open WOT before 40mph.
Thanks
Mike
1 - 16 of 16 Posts
I would call UpRev and see what they can do. www.uprev.com is the site I think.
Someone else's copy of Osiris will NOT work with your truck. You have to deal directly w/Uprev and either send them your ECU or purchase Osiris...
Thanks, i wnated to see if i could avoid the almost 1 grand. ok better start saving.
arrrrrgh... der be pirates amongst us!!!
MAIL-IN REFLASH:
1 Tune is $300
3-5 Tunes is $500 with Map Switching
Osiris is $710, same as 5 tunes, and includes Cipher so you can monitor your engine at any time.
Still my favorite Mod, for Performance and Safety reasons alike. No other Mods, helps you keep it safe like Cipher.
TitanBlue said:
MAIL-IN REFLASH:
1 Tune is $300
Yeah I ordered the whole package.Now I can monitor my ecu but wont have a clue what I'm looking at.
LOL.....i hear ya. There are a few on here that can explain WTH you are looking at. They cant tune in respect to Uprev but can "advise" you as to what to do. Either hang loose and wait for Uprev to reply or chew your toenails loose in the mean time.:jester:
I just want someone to tell me when I'm getting wot after my tune vs before my tune.
Thanks
Mike
Did you figure out your cruise problem? I'm going through the same thing!
swapping to 3.36 gears requires an ECU reflash. Beleive I know I was the first to this and thank goodness its an easy fix with a flash. Add $300 to your install and get the right flash done. Because your shift points are also affected not just your cruise.
Can a dealer do a reflash or does it have to be done by UpRev? Does UpRev need 91 octane or can they do a tune for 89?
The dealer could they have the means and tools to do so. Most will not. Best if you know someone at dealer. Yes Uprev can do 89/91/93 tuning
how did you swap the gears? or just do whole rear end
Axle swap with trutrac:
http://www.titantalk.com/forums/tit...36-trutrac-installed.html?highlight=axle+swap
My gears are getting swapped this week. I have 4x4 and I swapped out the front as an assy. and the rear I'm swapping only the ring and pinion. Still hope my dealer can flash my ecu instead of UpRev.
1 - 16 of 16 Posts
