1 - 2 of 2 Posts
I have a 2019 Titan radio w/navigation (NOT Fender system). When playing music from a USB (or CD) even though the files are contained in folders the system ignores the folders and plays the mp3 files in alphabetic order (or random order if the 'random' toggle is set). The owners manual says the files should play from each folder in the order in which the folders/files were copied to the media.
Does anyone know if there was a change to the radio software dictating file play only (ignoring folders). Or do I just have a defective radio?
Discussion Starter #2
To follow up, if anyone is interested: Mp3 music files will play by folder/album but you must 'turn on' the folder mode. To do that, do the following: With the USB in and playing, go to the USB menu and tap on Folder. Then tap a folder in the resulting screen. If there are no embedded folders in this folder a list of files will appear. Tap on one of the files and it will begin playing. You can now back out to the main screen. Music on this USB will now play files by folder as described in the Nissan Connect Manual (page 3-6). You will note the sequence of the Repeat button is now: none-All-Folder-Track-none whereas before turning on the folder mode Folder was not in the sequence.
1 - 2 of 2 Posts
