1 - 20 of 21 Posts
Used front skid plate off my 2014 Titan Pro-4X. I swapped with one that matches color of truck. Was on truck for about 3,000 miles.
Prefer local pick up. Could possibly ship, but I imagine shipping would not be cheap.
$125
I'm not entirely sure, but I think you will need mounting brackets that come standard on Pro4x.
That's correct. The Pro-4X skid plate utilizes a different mounting system than the standard/non-Pro-4X skid plates. The Pro-4x skid plates uses brackets that mount to the tow hook assembly.
Thanks for the replies. I'm still not clear on if they will fit my 2014 SV though because it is 4x4 and came with tow hooks installed. Also, are you selling the brackets you guys mentioned with the plate?
Morrow919, the Pro-4X skid plate will fit on your SV, however, you would definitely need the brackets that are specifically made for the Pro-4X skid plate. The Pro-4X skid plate mounts differently than your SV one. I know because I did this for my 2011 SL and just wound up buying the entire assembly. Very glad I did though - better protection and aesthetics.
Reactions: morrow919
He sp
1 - 20 of 21 Posts
