1 - 13 of 13 Posts
Just bought a 2015 Pro4x. Was always intrigued by the Utili-Track system and this influenced my purchasing choice.
I've done some cursory searches but was surprised not to find more products and projects for it and am now wondering just how useful it is.
Anyway, I have two projects in mind. The first is that I have a bed tool chest (see below) that I would like to fit on the bottom bed rails to hold it in place but also so I can position it in the bed wherever I want it and remove it easily.
The second is that I would like to do something similar with a crossover tool box where it would rest on the truck bed sides but be attached to the rail system through the sides of the box even if I had to use spacers between the side of the box and the rail. This would allow me to position the crossover box anywhere in the bed, remove it easily and not have to drill mounting holes in the top of the bed side.
I'll work on the first project first since I already have the chest. But I have some questions. First, what is the little thing in the second picture below? It came on the truck. One on each side. Maybe a stop? Not sure if it is OEM or not. But, my thought was this: take these off, drill two holes in the bottom of the tool chest, attach these to the bottom of the chest to hold the chest in place. Loosen then up to remove or reposition chest. Well, that won't work because it will not come completely apart. In other words you cannot unscrew the base. So that's a no go.
So my second thought is to use a proper sized bolt with a couple of thick washers that will be inserted into the track system. The sides of the washer will have to be ground down to make them flat so they will fit into the rail slot. Then, find a plastic or metal knob to screw down onto it once the box is in place. The only issue would be that the bolt would turn in place when I tried to tighten it or loosen it. I guess I could get a buddy to tack weld the bolt head to the squared off washer.
Anyone else tried this sort of thing or know of any aftermarket product which would fulfill a similar roll?
Thanks and apologies if this has already been discussed to death. A Google search didn't turn up much and not too many aftermarket products available on eBay or amazon.
I have my toolbox secured via the utilitrack. i can slide it forward or back if i need. it just stays in one spot tho. but i can remove it and don't have any holes in the bed. I've used them to secure a hi lift jack, and also have a bed rack for camping that slides in the rails on the bedsides.
utilitrack is AWESOME
If you want to be able to slide it in the tracks. I'd just go with two metal strips with nuts welded to the bottom of them to slide into the track. Lock washers and wing nuts in the tool box would make for a quick loosen and slide.
That's just my first quick thought anyways.
thats how i did mine. in order to completely remove the strips i have to remove the tailgate too lol. since the strips sit just a bit lower then the tailgate, and are too thick to bend easily.
Invest in some tie down cleats if you don't have them. Think there's a member on here selling sets of 4 right now. I use those all the time, store them in the OEM toolbox.
Reactions: oldf150 and Indy
That's why I'm thinking about just securing the chest with just two bolts toward the front of the box. That way when it is time to remove it I can just slide it to the end of the track and lift it up and out when those two bolts are clear of the end of it. It is not a heavy box and rode in my old Ford for 14 year unsecured so this will be a step up.
For the crossover box I will probably use this strip idea since it would make it more secure and would still be easy to slide of the end of the side rails. Thanks for the input guys.
Discussion Starter · #8 ·
I've got the 4 OEM cleats that came with the truck. The is a guy on eBay who sells a washer/bolt/ channel nut combo for $23 for four. I think I can make something up for less than that, similar to what you guys have described above. Will post back once I've made something.
Here is what I've put together:
On the left, 3/8 inch bolt with washers that fit perfectly in the tracks with a open end plastic knob from Lowes. These will secure a variety of things.
On the right, and even better, 3/8 inch channel nut with a 3/8 nut/knob both also from Lowes. This combo is perfect and can be removed without sliding it out of the track channel, just turn it sideways and pull it out.
Combinations of these should allow me to secure my tool chest and a cross over box.
Those look good. You're probably already doing this, but make sure the knobs are inside the tool chest/box and it's locked so people can't just take them off and remove the chest/box. That's why I don't leave my cleats in the tracks. If you loosen them enough you can just turn them to the side and remove from the tracks.
Discussion Starter · #11 ·
I found some limitations with this sort of arrangement. The tracks on the floor of the bed are not as deep as the ones on the sides. This means that the heads of the bolts that hold the track in place will not permit my homemade fasteners, or the OEM cleats for that matter, to slide very far. I was disappointed by this but was still able to use these to hold the tool chest in the bed as shown in my original post. It just won't slide.
I did put these inside the box so if the box is locked it cannot be removed which is nice. It is also easy to unscrew the knob and lift the box out so it is easy to remove and more versatile than a bolted in box.
The other problem I found with my homemade fasteners is that the lug that goes inside the track (channel nut) will twist when you tighten the knob so you have to be able to reach inside the track and hold the channel nut until it is tightened down. I suppose this is why some folks have used metal strips with nuts welded to them. That is what I will do if/when I mount a crossover box.
The bottom line is that this 'system' is fairly complex and you have to think about a lot of variables to get it to work just right.
Did you purchase the bed rack or fab it up yourself? Got any pictures?
1 - 13 of 13 Posts
