Sorry, as I know this is a previous topic but there is a lot of conflicting information.
What is the consensus fool-proof way to get the VDC Slip lights off? Mine are on due to replacement of my Spiral Cable/Clock Spring. I re-installed the existing Steering Angle Sensor. Below are the methods I am aware of...
1. From Off position, start car and drive straight under 5mph for several hundred feet to re-calibrate
2. Unplug battery for 24 hrs
3. Must be re-programmed using the Consult 3 (I think that is what it is called).
I tried 1 and was not successful. Will try 2 but wanted advice 1st and want to make sure you guys don't think it will cause any other issues with the computerized systems.
Thanks!
Thanks!
