Very strange situation/ 60 lb tire pressure!
I took my Titan in to have the tires rotated which I thought was a simple thing.
After getting the tires rotated, the truck ran harshly and after a week developed what I thought was a transmission problem with the truck having trouble moving in reverse and jerking/clunking.
After checking the transmission fluid ect. I decided to give the truck a full once over.
It turns out that the tires were inflated to 60 lbs! I asked the shop who worked on the truck and he said he just kept filling them until the low tire pressure code disappeared! (my sensors are defective because I used tire sealant in 2 tires 10 yrs ago...). He said he figured it must be the right tire pressure for this vehicle!!!
I reduced the pressure to 33lbs., unhooked the battery overnight to clear the ECM and now the dragging/ thumping problem is gone hopefully for good.
Not sure what issues that crazy tire pressure caused. Maybe messed with the ecm or drivetrain or brakes? Just wondering if anyone has any ideas...
