VKPro and NOS?
874 6
Is anyone running this setup? Any words of wisdom?
you cant run a UN ADJUSTABLE piggyback with nitrous would be very dangerous if not out right stupid.. ur best bet would be uprev and have nitrous maps like i have where they pull 4 or 6 degrees of timing depending on how big ur shot of nitrous is..
bigjimbo said:
Thats what I figured. I was looking at a 90 shot, but I see that you upped yours to 125.
I was reading that anything over the 90 wasn't worth it.
hehe after adding cams anything over 90 shot is DEFINATLY worth it, i wasted a ford lightning using a 125 shot of n20.. ran a [email protected] the trap speed tells me i should be good enough for a 12.7 e.t. but i need to get off the line faster to achieve this.. only way to do that is fix this sloppy *** transmission with a built one from IPT with upgraded 3200 -3400 stall converter upgraded valve body, and upgraded clutches/gears in the tranny
this will be my next major mods, then the real fun can begin, might even step it up to a 150shot :)
Sweet deal...how'd those new traction bars work for you?
