1 - 10 of 10 Posts
Is factory sunroof an available option on an '06 SE Kingcab? I'm looking at one to buy that has a sunroof, and the seller is unsure whether it's a factory one or aftermarket. Anyone know? It also has leather and heated seats, but he says it's an SE, not an LE. Are these factory options on the SE? Any help would be appreciated. Thanks.
YEs it was a factory option
OK, thanks. So I can compare this one with the factory sunroof, where is the switch on the factory one?
Not sure I opted not to get when I got my truck. On the Pathfinder My wife had it was up near the sunroof.
It was available but required side air bags and stability control to be added also.
My 06 crew cab has a sunroof factory. the switches are up on the overhead console by the compass and homelink. there is one to pop it up and another switch to open it.
Discussion Starter #7
Well, I looked at that Titan yesterday, and the sunroof was an aftermarket one, I think it was Webasto (sp?) brand, and the thing made a huge roaring noise on the highway. I mean, it was LOUD, like the window was partly open. When I looked at it from the outside, the sunroof was about 1/16" above the roofline. Can the sunroof be adjusted? I didn't buy the truck based on that noise, but if it's an easy fix, I'd reconsider. Anyone know?
The way that aftermarket unit sits it probably can't be easily adjusted...basically aftermarket sunroof units require the roof to be cut out, then the sunroof unit frame overlaps the top and bottom of the roof and headboard... You could always see if a sunroof deflector (similar to hood deflector and window visors) will help to deflect the airflow and reduce the wind noise???
Leather wasn't an option on anything other than the PRO-4X...and they didn't come around til 2008. Only the LE had the factory leather prior to 08.
1 - 10 of 10 Posts
