1 - 9 of 9 Posts
Has anyone ever had to replace the washer fluid nozzles???? The one on my driver side busted and sprays washer fluid straight up in the air. I have the new one, but can't get the old one out.......does anybody have any recommendations???? Thanks!
The driver side one you will need to pop the cowl up. The passenger side you don't, the hose can pull through through hole in the cowl...just be careful not to lose the hose. You can pop them loose with a putty knife reliving the clips on the left and right side of the nozzle.
1 - 9 of 9 Posts
