I had a similar sounding issue on my '04 KC, are you talking about the plastic clip that (almost) stops the ball-clevis thing from sliding out of the actual movement?
It broke on mine too, I have been running a year without it, I was able to twist the cable 120 degrees (doesn't line up right at rest) instead of the short twist direction and then the torsion on the cable is not all directed to that plastic clamp, and the whole thing holds itself together.
:huh:
Wow, if that doesn't sound confusing...
:huh:
