34k on the truck, warranty is still there. Even If I didnt have warranty I wouldnt be too upset about it, pinion seal is nothing too hard/big deal.that blows bud
Ya when the fluid gets low is probably when mine will start whining. You can actually see a drop forming in the pic, and lots of areas on the underside are covered in it....wish the rear end had a dip stick to check fluid level.mine did that 4 times until Nissan replaced my whole rear. What caused this was the pinion bearing, then the rear started to whine and i complained to Nissan. My truck had 98K, out of warranty but still they replaced it since I had a record of the issue.
Oh ya mines way worse lol, I wouldnt even worry about yours yours looked like it leaked a little and then clogged itself back up. Mines soakedThat suck's bro!
I just posted a pic of mine a few days ago, but it doesn't look as bad as yours:
No, and I didnt know gweasel was in an accident. I just think its an undersized rear end for all the torque of the motor.Do either of you think the accident's you were in attributed to the leak?
That is a possibility?Do either of you think the accident's you were in attributed to the leak?
