1 - 2 of 2 Posts
I have an 05 Titan and I noticed this spring when I was cleaning my truck that the passenger side floor was wet. I did some research and found the a/c drain issue and did the repair. However, after the fix the floor is still soaking wet. Next, I replaced the windshield and it was still leaking. I took the molding off by the grab bar and had a buddy take the hose and run water across the top of the truck and windshield while I sat inside. After about one minute, i could see water dripping in between the pinch weld that the glass is adhered to about three quarters of the way up from the bottom corner.
I have no idea what to try next to cure this problem and any input would be much appreciated. Thanks
1 - 2 of 2 Posts
