what code is C1109?
13120 4
:redblob" I was on cipher and clicked retrieve abs codes when I was just checking eveything out and it found this code. C1109
Its some sort or abs code it said. What is it and is it anything I should have to worry about?
Thanks
Roadster311 said:
Battery voltage abnormal. Did you have to jump your truck recently?
Never had to once. my voltage is around 13.4 when im playing music and when its just idling and driving around its around around 13.8 to 14.2
I also have 2 batteries. one under the hood and one in the back behind a seat
Roadster311 said:
could be an older residual code or even related to the additional battery installed in the vehicle. I wouldn't worry about it unless you start having electrical issues.
Thanks. I didnt even know about the code untill I was bored and just hooked up cipher and clicked retrieve abs codes and it found it and I was just wondering what it was.
