1 - 6 of 6 Posts
I'm new and looking to lift my Titan 3in... I've got a 2013 pro4x cc and am looking into different lifts. I want to go the 3in lift but have read about the CB contact problems if u add too much lift... Would I be able to do this 3in myself, what's the best kind of lift to do for the added height I'm looking for and what is everything I need to get in order to do it. If you need pics I'll be happy to post them thank you for any help advice opinions you have I'm all ears
Your going to need Upper control arms (Dirtking, PRG or Rough country), Extended endlinks (PRG), extended bump stops, possibly adjustable cam bolts, And then either a spacer or a combination of spacer and adjustable struts (Bilstein 5100's). Then you will need a block for the back and most likely longer shocks (Bilstein 5100's or 5125's)
1 - 6 of 6 Posts
