1881 - 1900 of 2910 Posts
· Super Moderator
Looks to me like you are bottomed out...
I am willing to come out and check it out if you want, I have helped to setup a few around here.
I offered my help... His trailer is NOT sitting level (.) regardless of his "rake", towing like this is not safe. I live here in San Diego and I know a little something about set up for towing. I believe he could be safe, but with the way that truck and trailer are setting it's not.
oh i see what your saying. the WD hitch just needs to be adjusted. i thought you guys were saying the trailer was too much for the T.
· Super Moderator
I think this can be setup correctly and be safe.
Reactions: GRAVITY and RobKar
· Super Moderator
Airbag are on order trust me, i just bought it on tues and picked up Friday... So I have work to do
Sent from my iPhone using AutoGuide.com App
I like the AirLift ones, if that helps you, its what I run. At one time I had Firestone, but the ride is harsh even unloaded with that bag.
Reactions: Tiradojt2
Hey Rob, u can help me install mine. Im gonna order AirLift soon.
Droid Sent
Reactions: RobKar
Yeah I heard that about the Firestones, airlift seem like a better quality kit anyways . Did you put a on board air system or just bring the hoses thru the bumper??
· Super Moderator
I have an on board compressor. Makes it easy to hook up with the WD hitch, then lower the pressure to the correct spot.
· Super Moderator
Where did you mount the compressor?
Under the back seat, there is a little shelf that fits perfectly. Ran the wires up to the center console with the gauges and switch.
· Super Moderator
Mounted my compressor in the right rear corner, between the box and fender (see the four stainless bolt heads?) Routed the remote air intake and filter to the cavity behind the right tail light.
It's been there for two years and works great.
