Need inputs on how to get the best timing advance. I have the BDPP of course it gives you *2. Whats the best?
hat has never peally been preoven. not saying that you're wrong.+4* would require higher octane gas.
I still wouldn't risk it.hat has never peally been preoven. not saying that you're wrong.
Deerslayer is running +4 on 87 with no problems.
i even ran it for a bit with no problems or knocking.
dude, i'd like to see 2* of timing adding 10-15 hp's that would be awesome.I still wouldn't risk it.
IMHO, 10-15 hp isn't worth a $4000 engine.
It's not that unlikely.dude, i'd like to see 2* of timing adding 10-15 hp's that would be awesome.
Well ive never tested this or anything but i could tell a pretty big difference with the 2* advance with just my pp. Drove it without the advance then added it and drove it again... seemed to make a good diff.dude, i'd like to see 2* of timing adding 10-15 hp's that would be awesome.
I had my 2* advance on when I had my truck dyno'ed in my baseline dyno thread. I wanted to see the difference that Thorley's TRULY made so I did a baseline run and going back after I get my truck back out of the shop.Well ive never tested this or anything but i could tell a pretty big difference with the 2* advance with just my pp. Drove it without the advance then added it and drove it again... seemed to make a good diff.
Should be. Worst case scenario is it will knock, a knock sensor will pick it up and the ECM will retard the timing until it quits knocking.I run 91 octane and have 3+ timing.
I've always been hesitant to go any higher.
Is it safe to go to +4, if I'm running 91?
After I have it back I'll try to remember to make a pull without 2* to see what the difference is.
If I'm not mistaken, the ECM can adjust +/- 2 degrees. I'm pretty sure that's the reason UpRev only allows you to adjust +/- 2 degrees as well, so if something isn't going right, the ECM can compensate.These engines have knock sensors. If you advance the timing higher than the ECU can safely adjust it while using regular 87 octane, it'll knock. Otherwise, you won't hurt anything. I took the 2 degree advance off because I didn't feel any difference. But my butt dyno must be off because a lot of people are claiming they can feel a difference...lol.
That would make sense. My BD can only do a 2 degree adjustment as well.If I'm not mistaken, the ECM can adjust +/- 2 degrees. I'm pretty sure that's the reason UpRev only allows you to adjust +/- 2 degrees as well, so if something isn't going right, the ECM can compensate.
If you advance it 4 degrees and it knocks. The ECM SHOULD detect the knock and retard the timing.Yea several ppl have said that but my question is will it always knock after that? or will it go away
