My 04 Titan I bought recently didn't have a tranny temp gauge even through it has the big tow package. I bought a Glow Shift gauge with sensor and an extra capacity tranny pan from PML. I don't know what the normal transmission operating temperature is, or should be, in degrees. Unlike the stock tranny temp gauges, my gauge shows the actual temperature of the fluid in the pan. But here is what I've seen so far. I drove 10 miles to the local Walmart at speeds up to 65 mph. I was almost at Walmart before the gauge showed any movement at all off the lowest temp mark, which is 80 degrees. I left Walmart for an auto parts store a few blocks away. By this time, the gauge was showing between 80 and 90 degrees. By the time I was headed back home, again at 65 mph, the temperature rose a bit more, and by the time I turned off the highway toward home, it had reached 120 degrees. I drove the last mile below 35 mph and about 5-10 mph into the lane to my house. When I parked, the temperature had risen to about 125 degrees and after sitting for 10 minutes it reached 130 degrees.
Is this a normal operating temperature, or is it lower than normal because of the extra 3.5 quarts of fluid and the fins on the bottom of the deeper pan for cooling? I haven't towed my 5000 lb trailer yet except to set the brake controller, so I don't know what the tranny temp will be when towing it. I'll find out in a couple of weeks when we go on a camping trip.
