ok guys im very serious on getting my wifes truck nicely set up for the next years Off road racing season in Baja.. so i was checking the Uprevs web page and they ask me which type of this 2 parts do i have so i assume they work.. i would like to know what are the best or good performance parts in this 2 categories since for cams ill be going with the s2/s7 from JWt.
so all the help on this matter is greatly apreciated..
I have an AirRaid TBS & i still like mine. Some people like them & some don't... It's personal preference. If you plan on getting Up/Rev than you should look into doing the '07+ intake manifold mod. also. It's good for a 10-15HP increase when re-tuned. :)
Also, some other supporting mod's that would be great for a S2/S7 Titan would be:
TruTrac (to get the power to both rear wheel's)
Long Tube Header's (Stillen or Doug Thorley)
Tru-Cool External Trans. Cooler
PRG Traction Bar's
TransGo Shift Kit
Long Tube Header's (Stillen or Doug Thorley)got JBA shorts
PRG Traction Bar's
TransGo Shift Kit
im working on most of the things you mentioned but i need to get a good price on this parts, im talking to a member here to get the transgo kit.
where did you get the TBS from? link?
I forget where i got it... Their pretty cheap though.
found it.. thanks now im looking for the intake manifold... any ideas..
intake manifold 07-011 new engine design differnet partnumber about 145 my price swap is easy unless new injectors are needed 04-06 diffrent engine then 07-11 can get part number if need
-nissan tec
You can order one from Nissan if you can't find one anywhere else. I got mine @ Harbor Nissan. That price sounds about right. There is a thread on here that lists all the part #'s you will need. You don't need new injectors. All you do it unbolt the fuel rails w/ the injectors still installed on them & swap them over to the '07 IM.
