are you 2wd or 4wd. 04-07 or 08+?
You can run a 2 inch spacer with out new UCAs and be fine. Anything more then you will need them
What JLG said, but I'd add that with a 2" kit you will want to get longer bump stops and also adjustable cam bolts. Good luck!
I was able to get mine aligned with out new cam bolts but every Titan is different
I mean, I've seen a 2012 with a 6" align without adjustable cam bolts :lol:
I figure it's not a bad idea to figure the 40-60 bucks into your lift budget. Better than getting the thing to the alignment shop and being told you are SOL until your 4 bolts come in :bang:
