1 - 9 of 9 Posts
I have a 2017 Platinum reserve with stock wheels and tire. I’ve installed a 3” leveling kick and want to upgrade to bigger tires while still using stock wheels. What tire size should I be looking at? I wanna fill the well as much as possible without rubbing. Currently there are 275 60 R20’s on it. I would like taller and fatter but stick with stock. Please help with the size
Thanks for your help
Discussion Starter #2
Did you ever get an answer about tire size? I'm put a 3 inch lot on my 2018 SL and I have the same size stock tires that you have. I want to keep my factory wheel on also but I not sure about the tire size I will need with the lift.
What brand did you go with? Truck looks nice!
I went with Cooper AT3 XLT...... I wanted an aggressive look but I didn't want the humming of a loud mud terrain. So far they are a great tire and they offer a 55k mile warranty.... So when I was looking I also looked at the 305/55/20.... That's basically a 33" tire..... I just wanted it to be taller so I could fill in the wheel gap. The 305 is a little wider than the ones that I have and I didn't want mud or dirt all on the side of my truck..... Hope it helps and thanks for the compliment.
Did you put a
Thanks for the info it was really help full in helping me make my decision.
1 - 9 of 9 Posts
