Just picked up a set of 5100's and I was thinking instead of using my factory springs (7X,XXX) miles, I might just just get something better. What can I run with the 5100's that will just mount right up and don't require any modification and wont give me any additional lift?
I would stick with your factory coils if you don't want lift. Since your 2wd if you get any stiffer spring it will raise you. I put 08 4x4 coils because I didn't want to run a spacer up front on middle perch it got me to over 40" with 275 70 18 and stock rims (2005 2WD). I went to lowest setting and I'm sitting at 39 and some change. Ride is alot better. moog 81196 vs 81194 vs 81198 if you want to research aftermarket springs. 81196 i believe would be the moog part number for a direct replacement. Only thing is I saw reviews where they start to sag after a while that's why I went with the 81194. Just be warned if you get the 81194 they will raise you and they will be alot stiffer especially after 1st setting because of the preload.
Discussion Starter #4
I wonder how level I would sit.. I would be running Maxtrac spindles, 5100s, 81194s(potentially), and then a 2" block in the rear with 5125s?
