i would say BFG ko2 or toyo open country AT2. the KO2's are "snow flake" tires. the extreme weather rating thing.
Those federal couragia? Cheap for a reason.
Good to know, thanks, the couragias do they just wear out crazy fast?>i would say BFG ko2 or toyo open country AT2. the KO2's are "snow flake" tires. the extreme weather rating thing.
Size is totally up to what you use your truck for, what type of mileage you're willing to take and what kind of stance you want. I personally love the look and function of mine, but they'd probably be too wide for someone who uses their rig mainly for towing for example.What size would you guys recommend for the Ko2s? Guess im going to get those. Just wondering if I should go larger than 285
Ok ill just stick with 285s didnt think that bigger would start rubbing at that point. Thanks.If you're on stock rims and stock height I'd stay with 285's, imo anything bigger or wider just looks stuffed in there and you have to deal with rubbing in many cases. I'm on my third set of 285's with a front level kit only only way I'd go bigger is if I bracket lifted and/or went with wider wheels.
why do you say th 75 over the 70?look into some tires in a 285/75/17. had those before my current set.
