There are a ton of sizes to choose from.. it seems the 295/70/17 has been the popular size recently.. in a nitto tire.
Thanks. Yeah I am looking for an aggressive type look, something that may stick out slightly past the fenders. I wasent sure if a standard 285/70/17 would fit ok on the 17x9?There are a ton of sizes to choose from.. it seems the 295/70/17 has been the popular size recently.. in a nitto tire.
I am getting ready to have the 1.5 inch leveling kit put on my truck and plan on going with the same tires you have the 295/70/18 Nitto All-Terrains. So you are saying you don't need the PWM? If no then that will save me a little money. Please let me know.Should not rub at all.
It all depends on the offset of your wheels. You can fit up to 33"x12.5" r17 on stock 17" wheels with zero rubbing and no modification required, so 295/70/17 should be no problem. But if your rims have a negative offset, that's when you will get rubbing and need the PW mod. If your wheels have a more positive offset similar to stock, you won't need a leveling kit or pw mod for anything up to 33" x 12.50" tires. Mine never rub even when I bottom out the shocks with the wheels at full cut. 33x12.50r17 fits like they were meant for the truck on the stock offroad wheels.
Like I said, it all depends on the offset of your wheels. If they have a negative offset then you might have to do the pwm. If the offset of the wheels is close to that of the stock wheels, then you will be good. So find out what the offset is on the wheels and then you can have a better idea if the pwm will be required.So if I'm reading your post right I should be able to fit 295/70/17 Nitro on
17x9 wheels without out out PWM? I have a 2" leveling kit on the front.
What is the offset of the stock wheels?Like I said, it all depends on the offset of your wheels. If they have a negative offset then you might have to do the pwm. If the offset of the wheels is close to that of the stock wheels, then you will be good. So find out what the offset is on the wheels and then you can have a better idea if the pwm will be required.
:bump: Thanks for your post, I'm new to Titan Talk and am learning everything. I just ordered the 1.5 inch leveling kit from PRG and am going with 325/60R18 Nitto Terra Grappler All-Terrains on my factory Rims. :redblob"i just need to post on this thread if only to show my signature....
