1 - 3 of 3 Posts
Im new to wheels, what are the requirements for a aftermarket wheel for the Titan--ie load,offset,lug spacing etc. ?
if you are just putting them on a stock suspension, you can get all the info at your local tire shop. They have all that in a book or on their computer. If you are lifting or lowering, you will have to play around with the offset a little bit.
The bolt pattern is 6X5.5 or 6X139.7mm.
For offset, it depends, stock is +25 to +30mm depending on 17 or 18 inch rims. Closer to zero or negative will push the wheel out, close to stock will keep them tucked under like...well, like "stock."
The stock 18" on the LE and SE are 18x8", and the 17" off-road and XE wheels are 17x7.5".
Hope this helps for a baseline.
1 - 3 of 3 Posts
