I have a lifted nissan titan with a front wheel wobble. The wheel bearing seems good but there is a small crack where the hub connects to the main body of the bearing. Will the weakening of the hub cause a wheel wobble? I believe that everything else in the front suspension is fine. The wobble is significant enough that the rotor is rubbing on the brake cage causing it to squeek. If its not the wheel bearing is there anything else it could be?
Its cracked and your not sure if you should replace it? It will get worse. Mine did that, i thought it was my brakes with dust on them, than the wobble got worse. I'd get it replaced. Pretty easy diy.
A cracked hub needs to be replaced.
If your hub is cracked...whats to stop it from completely falling apart, and your tire passing you as your going down the highway?
