1 - 2 of 2 Posts
I am going to get the 4" PRG performance lift and wanted some advice on a wheel and tire package I found. The wheels are 18x9 1/2" and have 4 1/2" of backspace. The offset is -19. the tires are 33x12.50 Nitto Mud Grapplers. Do you think I'll have any rubbing issues? Also, I don't want a wheel that sticks too far out. Any input will be appreciated. I am pretty set on the Performance lift with SAW coilovers, PRG uca and DR or SAW rear shocks, but am still considering the 6" Procomp and adding the goodies later. the 6" would definately mean 35's. Are any of you disappointed with the amount of lift from the 4" performance kit?
I had a similar thread..However my question was whether 35's would clear...Read on...thanks..
PRG's 4" Performance Package?
Does anyone have this setup on his/her truck? If so can you post some pics.. I am curious to know if this 4" inch lift can easily clear 35's on a 17x9 rim w/a 4.53" backspacing. If so, I am leaning more on purchasing this setup VS the pro-comp 6" stage 1 lift kit. I've heard a lot of positive things about Greg's/PRG's products & the installation of this kit looks much easier then the procomp...Thank you..
PrerunnerGreg
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: PRG's 4" Performance Package?
You wont clear with those rims. 35's will rub with anything other than the stock offset. And toyo, nitto, procomp and cooper 35's are all too big.
Thanks for the input Greg..So if I find some after market rims w/the same stock offset will I be able to clear 35's, or just 33's? Please advise. Thank you...
that is what i recomend. Or if you want a bigger tire, look at the procom, toyo, nitto or cooper 33's, as they are slightly bigger than other brands of 33's. or possibly 305/70-17. 35's can fit, but be prepared for the possiblity of clearance issues.
1 - 2 of 2 Posts
