1 - 9 of 9 Posts
Hey guys,
I was replacing my rear drive shaft U joints today when I noticed the rear yoke that connects to the rear differential had chunks taken out of it around where the clips sit, so much so that the clips for the new U joint wouldn't even stay in on the one side. Anyone know where to find this part? Its #6 in the diagram below. Thanks
http://www.titantalk.com/forums/att...285863734-driveshaft-bolt-torque-capture3.jpg
There are 3 different styles i believe, so we'll need to know which one you have. I know there is on made between 04-07 and a different one for 08+, and also an aluminum version (from what ive read online, never seen one though)
Try the parts guys at Courtesy Nissan. CourtesyParts | Genuine OEM Nissan Parts & Accessories. I've had good service by them.
They recently changed their online parts catalog, and it's much harder to find what you are looking for than the older Nissan parts system/diagrams. The link called "propeller shaft" shows the rear axle. Not helpful.
Give them call at 1-800-527-1909 or email the diagram to them at [email protected] - suggest including your VIN. I'm betting they can help you out.
Good luck!
Reactions: Natevb23
I have an 05 titan, thats wild they make an aluminum one. I'd be concerned with longevity on that one.
Good luck!
Thanks, I'll give them a call today.
No luck, Courtesy Parts does not sell the yoke separately, only the whole propller shaft. Any other ideas?
I would normally say Rockauto, but their site says they are "Currently Out of Stock".
You could try an auto recycling yard nearby to see if they have a Titan.
Discussion Starter · #8 ·
After a couple hours of digging, I found that Spicer does make universal yokes and Summit racing sells them. I ordered from the link below.
Spicer Drivetrain Products 3-2-1879 Flange Yoke 1350 Series
All the measurements were spot on so we shall see. I'll keep you guys posted on the fit. Thanks for your help
The part was just delivered today....crazy fast shipping btw, and its a perfect match! Will be pressing the new u joints in later today.
1 - 9 of 9 Posts
