I cannot seem to find online any place that sells the cover gasket fot the Nissan Dana 44 differential. I don't want to drive 30 miles to a dealer to get one. Any help here? Actually, i need two gaskets. I want to remove my finned, aluminum diff cover from my 06 Frontier that I'll be selling and put it on the 04 Titan i just bought.
Not sure what key words you were searching, but a quick google search for "nissan titan rear differential gasket" came back with a few hits.
Try searching for Lube Locker part # LLR-D044. That looks like it may be what you're looking for.
All of the DANA 44 gaskets i've found are not the ones that fit the Nissan. I have decided to just use the red, high-temp RTV gasket sealant.
The lube locker gasket for Titan is different. You can order one only from Mag-Hytec. They included one with my Mag cover. You can order new replacement ones on their site.
Thanks, but I will use the red Permatex silicone gasket in a tube. I found and cleaned up my original diff cover and the factory gasket was silicone (gray, not red). I believe that I can do the gaskets on both trucks with one tube for $7.99 plus tax. Today the diff cover gets swapped on the Frontier then I can put my for sale ad on Craigslist.
