Like the title says....I mounted a 20" LED in the lower slot under the bumper and want to wire up a switch that is powered from the hi-beams to trigger the relay. Had it this way in my last truck and liked this system. (can only come on with hi-beams, but can turn it off) Wondering if there is a wire under the dash easily found, or do I need to pull the inner fender out, get into the harness to the hi-beam bulb and solder a wire onto the +.
