I hooked mine up to a wire that is hot only then the ign. was on......when the truck shuts of, then so does the amp.Jon_UT said:i can't read any of those diagrams for the life of me. I have read the stock remote wire is a violet color, but i just looked and I have like 3 violet wires to choose from.
And a good place to tap one is at the aux 12v outlet under the heater controls. The one on the right is only on with switch.rgregory1965 said:I hooked mine up to a wire that is hot only then the ing was on......when the truck shuts of, then so does the amp.
Works like a charm.
Use a low voltage trigger like this.eakes said:First, be aware that the AMP ON lead from the Fosgate system does not provide 12 volts DC, it is more like 6 to 8 volts - this may or may not turn on an aftermarket amp.
