I tried to order the part locally, and was told it was unavailable. Most llikely that is just because of my region. It is an almost must have available item in your area. The price of the OEM heater was only 30-40 dollars. So, I would go OEM if they can get it for you.
Also, there are the glue on Pads, and bolt on magnetic models to consider. The Magnetic are common in the stores. Pads are available at Jegs and Summitracing.
We use heaters on all of our diesels at work, and I do plan to get something on my Titan. I already have a Magnetic on hand.
Some will say they start up without a heater needed, but wear on bearings/starters/wiring is decreased on a warm engine block.
