Where should I mount the toggle switch
  • Left Console
    Votes: 3 42.9%
  • Center Console
    Votes: 2 28.6%
  • Upper Console
    Votes: 1 14.3%
  • Other
    Votes: 1 14.3%
  • Total voters
    7
1 - 10 of 10 Posts
Going to install some lights on the front of my truck soon and am deciding where to mount the toggle switch. I have a bare bones SE model with a bench seat and here are my options:
Left console where the rear power window switch is-I have two empty ports.
Center console just above the cupholders next to the tow mode button- I have two empty ports.
Roof console where the temp/compass, garage door things typically are- I have a "blank" cover there with nothing on it. (This location would give it the aircraft type effect I think)
My personal favorite is using an old style floor mount dimmer switch. Hands free for convenience and so I can zap those a**holes that drive stupid.
Discussion Starter #4
Hehehe... that's a great idea. My 76 Cutlass had one of those and so did my old Ford truck. They are great.
That is where I put mine. I carved the empty port out to fit the lighted switch and it fit like a glove. Perfect!
I'd like the toggles on the upper panel but I'm wondering about the side-curtain rollover airbags. You may not have those, but I do and have that concern for disassembly of the A-pillar.
how about on your forhead for starting such a dumb thread..desicions desicions?:stab: j/k can you still ake me a skid plate?:dunno:
Oh, I get it. Slice him up, pour salt in the wounds, and then hit him up for some freebies. That'll work! :lol:
I mounted a standard on/off plastice switch above my cupholders for my amp shutoff. Easy to access, close to dash for wiring and it looks great. Plus, if you mess up cutting the access hole in the blank, it is under a little lip that will help to cover/shadow any fine details or mistakes. Not a problem if you use a dremel.
I mounted mine in the middle spot on the left console. The toggle lights up when activated, and the steering wheel blocks / keeps it out of eye shot so it's not distracting.
1 - 10 of 10 Posts
