Bought my first Titan (2006 LE, 155k miles) about a month ago. Everything seemed great at first...and then.
The first sign something was wrong was the CEL/SES light came on. Checked it with my code scanner, and I had a code: P1148 (closed loop bank 1). Cleared it, 2 days later, got P0171, system too lean, bank 1. Starting to think I needed a new oxygen sensor/AFR. I cleared it again, and then got those two codes again. OK. Probably should get a new oxygen sensor/AFR. Then, I started having white smoke puff out of the exhaust on startup. :eek_surprise: Found a thread here that spoke of replacing the PCV valves. Ordered a pair on Amazon, and the problem continued to get worse while I waited for them to arrive. 2 days later, when they arrived, the truck was running terribly. Had codes for misfires in cylinder 8, and a "general misfire" code. ::crying:: That evening, I drained the oil (no milkyness, just dark, and about 2qt. low), put in new 5W-30 full synthetic, a new oil filter, new PCV valves, and 8 new spark plugs. I also took off the PCV hoses, sprayed them out with carb cleaner and then ran a bunch of patches through them until they were clean. Coolant reservoir has been full this whole time. No white gunk/sludge on the inside of oil filler cap.
The next morning, it started and ran like a champ. Cleared codes, they haven't come back in 2 days of driving. However, it still puffs white/blue smoke (though not as much) on startup, and under hard acceleration. Help!! When reading about the PCV valves, a lot of people said to replace the valve covers - did they mean replace the entire valve cover, or just take it off, clean it and replace the gasket?? I don't know if this is just residual effects of having clogged PCV valves, or if something worse is going on...
Help! What should my next steps be? I'm about ready to just trade it in and walk away, but I don't want to lose a ton of money on this thing. I'm fairly handy with a wrench, and willing to tackle just about anything. Thanks in advance!
