Hello All,
I have a 2005 Nissan Titan 5.6 SE with 150,000 on the odometer. Last week it got down to about-5 here in Minnesota. The truck wouldn't start so I attempted spraying starting fluid in the air intake with no results. I didn't think it was the battery so I didn't immediately replace the battery. I replaced the battery today and it started right up. However, it spewed thick white smoke that smells almost like the truck is flooded. I let it warm up then drove it around the block. Near the end of the drive, the truck's idle became increasingly rough and the engine became really quite even when I pushed on the gas. It didn't fully die but I turned it off and parked it. Any suggestions or ideas about what may be wrong? I did get some starting fluid on the MAF sensor.. could this make a difference?
This is the first starting problem I've had with the 3 Nissans that I've owned.
