White Smoke
1566 2
Just asking about white smoke upone engine start up. It does not blow smoke when driving or accelerating but simply when I start it up. I did notice it once when I started it up cold and drove about 20 miles and it did it again (only at start up). It is cold (30-50 degrees) outside, and dad seems to think everything is ok...just getting another opinion...
1 - 3 of 3 Posts
White smoke on cold morning can just be from water condensate in the exhaust. White smoke can also indicate burning coolant from, e.g., a leaking head gasket. If that is the case the coolant level may be low, the engine oil may have an unusual appearance and you may smell antifreeze at the tailpipe. A head gasket leak can often be detected by a compression test.
Humidity levels and condensation. I was down in mexico with my truck last summer and my truck was white smoking I was like wtf?? Unless its excessive white smoke, like a diesel truck but white smoke then you should be fine. check the coolant level just to be sure.
1 - 3 of 3 Posts
