Who has 8w7's?
8.3K views 24 replies 11 participants last post by  Titano24's
I was just searching around looking for the people with 8w7's and can't find them. I know people have them. If you have them in your truck, post a pic. Also tell what your box is...ported, sealed, volume, up/forward/down firing, etc. I keep thinking how cool it would be to run a couple of those instead of my 10W3's, but am afraid they won't go low enough in a sealed box and there would only be enough volume for a single 8w7 if I went ported. I think the output would be lower than what I currently have with only 1 8w7. Please tell me I'm wrong. Also, if you have any comments on what your 8w7's are "louder than" or "sound better than" to you, that might be helpful too. Thanks!
#2 ·
I personally do not think an 8w7 would sound louder than 2 10w3's. Its just a matter of cone area. If your giving the same amount of power to both applications, I think the w3's will out perform a single 8" woofer. UNLESS, you just happen to build a kick *** ported box for that 8". It would have to be in every respect, "Perfect."
But I still dont think the frequency response will hold up with the w3's.
Just an opinion.
#3 ·
w7's are a different kind of animal, two of them sealed will sound far better than those w3's IMO
you dont really have enough room to port them properly. Id seal them firing forward with abou 1-1.2 cu ft sealed depending on your box buidling skills send them 300-400 each
and youll be more than happy
they just are rather costly, but sound good IMO
#6 ·
smoketitan said:
the only way to do that is with fiberglass, and I still think he has those 8w7s choked on volume
as there is NO way that there is 4 cu ft in the rear of the titan. he must be using a TON of polyfill
Yep and the force is strong in that young man.
#7 ·
Just an opinion.
Output is about displacement which is a factor of cone area and travel. A 10W3v2 has 3% greater displacement than an 8W7. You need a 100% increase in displacement before you get a noticable difference. So you can say that the 8W7 has the same output capabilities as a 10W3v2. They both have the same power handling but the required enclosure for the 8W7 is larger. Probably not pratical as an under-seat application.
As far as SQ, the W7 represents the best sounding woofer JL Audio knows how to manufacture for the price. The W3v2 is older than the W7 so it does not benefit from the DMA optimized motors the rest of the line does.
The advantage of the W3v2 in this case is the lower price, smaller mounting depth and flexibility of impedance choices.
The Stealthbox does not use the 8w7 because it's not small enclosure friendly being a high-efficiency subwoofer. The 10W3v3 will outperform an 8W7 if the later was shoe-horned into an enclosure that is too small.
#8 ·
Aright...heres the deal. I honestly dont know much about the sound system, but at my local Audio Video, they said they put 2 8w7's in a Crew Cab Titan and it sounded amazing. A friend hooked me up and now i have 2 8w7's and a 500/1 amp (not yet installed). Im planning on keeping the RF speakers and head unit for now though.
What do you guys think? Should i get a different amp to run them both, or will the 500/1 run it fine? What else should i get?
#9 ·
8s won't go so deep. A single 10w7 or a pair of 10w6 would probably be good. Also, don't leave out the Image Dynamics IDMAX. Good sub for less.
#11 ·
JL Audio 12W7 vs. Image Dynamics ID MAX 12 v.3 D2
Specification JL Audio 12W7 Image Dynamics ID MAX 12 v.3 D2 Notes
MSRP $749 $450 More bang for your bass buck!
Continuous Handling Power 750W 1000W The ID MAX can handle more juice
Linear Xmax (one-way) 29 mm 24.9 mm While both subwoofers offer impressive Xmax, the W7 has the slight edge.
Efficiency 86.2 dB 93.1 dB The ID MAX requires less power to play louder.
Nominal Impedance 3 ohms Dual 2 ohms Need a sub with a flexible impedance? You can wire up the ID
http://www.cardomain.com/brand?id=JLA for either 1 or 4 ohms.
#12 ·
are you sure you have heard the 8w7 in its proper box?? it doesnt go low?? ill admit 10w7's go deeper with more force, but they dont fit, and there is no way a idmax is going to fit in a titan , if you plan on keeping the rear seats man
dont send the guy off on a goose chase lol
and the w6 output and technology is no where near the w7 for output and low distortion, but hey
#14 ·
well. thanks guys. I guess i'll just stick with my 2 8w7's and 500/1 amp. Im going to try and get them installed in the next few days. They should work fine with the "RF" speakers i already have, even though they are not actually RF, they're good enough for me.
What do you guys think would be a good box, wires, and installation price?
#15 ·
Car Domain is a poor source for comparison. There are not technically competent people working there and everything is spun so what they sell is best....hmmm.
I am not sure why we are talking about 12W7 when the 8W7 fitting was in question.
The biggest BS specification is straight out of the pages of Crutchfield. Efficiency is not a good indicator of output. The higher the efficiency, the larger the enclosure needs to be to reproduce low frequency. Do you want high efficiency or small enclosure? You can't have both. Low efficiency drivers will have much more output in a small enclosure than a high efficiency driver will. This is why I stated that the 10W3v2 would out-perform an 8W7 if the later was in an enclosure that was too small.
There are lots of other reasons the W7 is the woofer of choice and why it costs what it did. Other woofers did not come up until you hi-jacked the post so it's moot.
#16 ·
Good luck with the system. Make sure your installers build the proper enclosure and set the amplifier's sensitivity as outlined in the Owner's Manual Appendix B.
#17 ·
You won't go wrong with W7's its the subwoofer all others are judged. Still king of the hill in SQL regardless of what you hear. 8's will work really well for rock music and you will have to front fire them unless you plan to take out the rear seat. Although front firing is not ideal it's about your only option.
#18 ·
check the avatar, install FINALLY getting done after i changed some things around, 2 8" w7's on a jl1000/1
#19 ·
If you can only go 8s, go 8W7. If you can go bigger, go IDMAX first. But for true deep notes, the 8" isn't going to do it regardless of how good it is. You need a larger driver. The FS on the 8w7 is 32.5Hz. The 10W6 in comparison is 28.5Hz and a 12w3v2 will go to 24Hz. Sure, the 8 will have more punch and more SPLs, but it won't go as deep. :huh:
#20 ·
I'd be very interested to see the install. Those are nice subs and will sound great. The only thing I can say is how can you stick with the stock stuff up front especially when your going with the 1000/1? My guess is that the stock fronts will be coming out soon...seems like a fine wine with some mac-n-cheese! We will be waiting for the pics!!
#21 ·
well my install is different than the guy that started this thread, i will be replacing all components and running the jl 450/4 for the highs all the components will be jl xr model 6.5" speakers. as soon as work slows down i should be able to drop off the truck
#25 ·
hmm i'll take that into account guys
