1 - 14 of 14 Posts
Who's using AMSOIL, in Oil/Filter & Trans & Diff ??
Where did you get it from ???
I hear alot of people talking about in the the Transmissions.
It's not in my tranny yet but I put it everywhere else. I just get it from the local NAPA store but I get a discount from them.
bigsal51 said:
do they have a dual oil filer set up for synthetic oil. I was wondering if you could do that like big diesal.
Why yes, yes they do. Here's the link that shows the setup and how to install.
http://www.amsoil.com/bypassfilters/2007_Nissan_Titan.pdf
Anyways, I am currently exchanging all of my fluids in the truck to AMSOIL. I just put in the 0W-30 Signature Series with the EaO13 Oil filter. Today, I just ordered the Severe Gear 75W-140 Gear oil for the rear differential. Eventually I will replace the front differential and the transmission fluids with AMSOIL products when I get the time/money.
P.S. I'm looking forward to not having to change my oil for over 20,000 miles :upsidedow
I use Amsoil, order on-line shipped right to your door in two to three days.
www.amsoil.com
I ran amsoil , 5-30w - 15k once and after even adding a quart on my 12k change it thickened up I think...lost some mpg as the oil got older.
I now run either Amsoil or Moblil about 8k then perform a complete drain filter change..put in the severe gear 2 yrs ago and have only checked it...:dunno:
Just Asking cuase I might get into being a Amsoil Dealer,
I have people come to my "Stealership" & ask for it then they go out then go out & order it..
HMMMM
HMMMM
You might start using it then if your planning on selling otherwise......uuhhh
I switched to AMSOIL awhile back and will not be going back to conventional ever again. Great Stuff !!! I liked it so much, I'm now an authorized AMSOIL dealer located in Virginia. Anyone who is interested in ordering, please check out my website at lubedealer.com/cwsynthetics.
I used it in my last Chevy and changed it around 20 to 25K miles with no problems. I use it in my 06 CC and already have 80k miles on it with no problems. I haven't used the tranny fluid, but am sure it is good stuff. I also run Amsoil in my car.
I am responsible for a balanced and blueprinted 1972 Citroen DS21.
Built in 1972. Runs Amsoil since built. Has 380,000 on the motor. Uses no oil. Runs great.
Nuff said?
Does anyone know the New model number for the AMSOIL dual oil filter bypass that will fit the 07 Titan? I want to upgrade to it but have no idea on the size of the thread for the filter to get the adapter.
Banned
Here is an installation of a dual remote bypass for a 2007 Nissan Titan 5.6 http://www.amsoil.com/bypassfilters/2007_Nissan_Titan.pdf?zo=1181889 . You can also call AMSOIL tech support at 713-399-8324 M-F 8-5CST. I can get it for you at wholesale if you like. Hope this helps.
I ordered it and put it in my trans this time. Noticed an improvement for sure there.
Engine oil I stay conventional. I get a discount at the shell station so I just keep it fresh.
Rear diff I use whatever synthetic I find at the auto store when I change it. I think I have valvoline in there now.
1 - 14 of 14 Posts
