Because 90mm is better than 74mm. And there isn't enough material in the oem TB to remove. Plus you would have to have a custom butterfly plate made. To get maybe 77-78mm, it's not worth the expense.
I picked up 21 rwhp 20rwtq thru entire power band going from stock 08 manifold, stock titan TB and custom 4in cai to the mgt90 90mm snout graft and ls7 90mm TB and using same 4in cai.
Biggest gain was at 5700rpm of 27rwhp. Power thru the rpm curve is what matters, not peak.
So hopefully the next gas engine titan will get a 90mm setup. Seeing how in stock form the VK56 engine was choked up and robbed by atleast 18-20rwhp.
Not including what a 4in intake gains over stock intake.
Also throttle response is much better. It's all in the hands of your tuner.
