1 - 1 of 1 Posts
Supporting Vendor (Gold)
HALO automotive is a manufacturer of very high quality Japanese lighting products. HALO not only provides top notch products, but warranties that are among the best in the industry. From its establishment, Halo has been committed to creating lighting products that not only perform well and look cool, but provide a higher degree of safety for drivers.
These are all very good things, but isn’t that what the other guy is going to say about his products? What ensures that your HALO bulb lasts longer and burns brighter than the other guy’s bulb? Take as an example the humble halogen bulb, which illuminates the road for millions of drivers today. HALO halogen bulbs use a more tightly wound spiral filament made of finer wire in a precise mixture of higher pressure halogen and xenon gasses than a standard halogen bulb. The presence of xenon gas under high pressure yields a higher rate of halogen regeneration, which means brighter light and longer life for you. Depending on the design, a 55-watt HALO bulb can produce the equivalent light of a standard 85-watt bulb, but without the amperage draw and heat of a standard 85-watt bulb.
This sort of craftsmanship can be found in all of HALO’s lighting products, including LED, HID, and halogen. HALO will burn brighter and last longer, and this is backed by HALO’s outstanding warranty on all of their products. Visit Halo Automotive Replacement Light Bulbs For Your Car! and try out HALO, you’ll be glad you did.
1 - 1 of 1 Posts
