There are a lot of factors that determine whether a wheel will fit or not some 17" wheels will fit, some will not. Bolt Pattern, width, offset, x-factor and hubsize all factor in. Your question is pretty vague. Post up the width bolt pattern and offset and we should be able to tell you if it will fit or not. Assuming they are the correct bolt pattern width and offset, you should be ok.
